TwinTurbo.NET: Nissan 300ZX forum - Re: If the compression readings are accurate then I'd say
Subject Re: If the compression readings are accurate then I'd say
Posted by ouikikazz on July 26, 2012 at 1:21 PM
  This message has been viewed 253 times.
In Reply To If the compression readings are accurate then I'd say posted by Evan_Wright (Ca) on July 25, 2012 at 09:52 PM
Message going to pour some oil down my cylinder walls make sure they arent washed down with fuel then im going to retry, if it doesn't work then im redoing the timing belt...
i got my nistune hooked up finally, it was a computer issue, uploaded a base tune for my cars upgrades so only two things left is dumping some oil down the cylinders and timing belt check if all else fails
