TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Only 4 things to make an engine run..
Subject Re: Re: Only 4 things to make an engine run..
Posted by ouikikazz on July 25, 2012 at 7:49 PM
  This message has been viewed 291 times.
In Reply To Re: Only 4 things to make an engine run.. posted by ouikikazz on July 25, 2012 at 07:29 PM
Message just to point out what i did after i pulled the motor:
new rod bearings
new oil pump and pickup tube
new 740cc injectors
300d fuel rail
new AN lines
new aeromotive FPR
new aermotive fuel filter
deleted fuel dampner
120k kit w/ramsey studs
ATI dampner
new fan belts
new seal and gaskets on valve covers
new detonation sensor and harness
new fuel temp sensor
new coolant temp sensors
new o2 sensors
new double innovate widebands
new efi harness (95+)
new die hard battery
new RPS carbon carbon clutch
selin MAF translator w/2 MAFs
new vacuum lines
new PCV valves
new coolant lines
new alternator harness
things that shouldn't matter:
new 3" SZ downpipes
new msp manifolds
675rs turbos
new full 3" SZ exhaust
PTU and CAS tested out fine
no boost leaks
all coil packs ohms within spec and has spark
new ignition and fuel pump relays
dual walbro pumps w/ash's fuel pump controller
