TwinTurbo.NET: Nissan 300ZX forum - Re: Only 4 things to make an engine run..
Subject Re: Only 4 things to make an engine run..
Posted by ouikikazz on July 25, 2012 at 4:54 PM
  This message has been viewed 259 times.
In Reply To Only 4 things to make an engine run.. posted by Drunkpunk082 on July 25, 2012 at 04:41 PM
Message coil packs all ohm'd out properly and still testing to make sure they spark through (arc/ground test), spark plugs are brand new iridiums, all injectors and plugs and efi harness is new and attached, i'm waiting a few to do a compression test don't want to flood the engine too much after making sure there was spark in these coil packs...will keep the updated
