TwinTurbo.NET: Nissan 300ZX forum - valve timing control solenoid valve leak?
Subject valve timing control solenoid valve leak?
Posted by Zinprogress on July 25, 2012 at 1:41 PM
  This message has been viewed 582 times.
Message So I was having a leaking problem before on my car and was told it was coolant lines. I took off my transmission and they werent leaking (But I did replace all possible lines I could get to) and with my luck it is still leaking. I took off my plenum and valve covers ( mainly to simplify some stuff and get them painted) but I also took out the Vtc solenoid and looked at it and you can see right through it. The passenger side you cannot I was wondering if it is possible oil is leaking from that because it gets all over firewall turbo tranny etc. If that is possible where can I get another new set?
