TwinTurbo.NET: Nissan 300ZX forum - Other wiring problems can give this symptom as well.
Subject Other wiring problems can give this symptom as well.
Posted by ZXoltan on July 23, 2012 at 7:59 PM
  This message has been viewed 229 times.
In Reply To Hit bump, car dies, not a connector, fuel related likely posted by treese88 on July 23, 2012 at 08:51 AM
Message Check the connectors by the main underhood fuse panel. It can be fuel components as well, like a bad fuel pump, but the bump issue makes it sound more like a bad connection. Try wiggling the wires around while its running- if you recreate the symptom you know you're on the right track. You should also check/ replace the fuel hoses if you smell fuel.
