TwinTurbo.NET: Nissan 300ZX forum - CAS alignment
Subject CAS alignment
Posted by inf on July 23, 2012 at 2:53 PM
  This message has been viewed 435 times.
Message Does this look right? This NA I have is having the absolute worst time passing smog. I've verified that EVERYTHING is correct that I can think of...EGR valve, solenoid, vacuum leaks, catalytic converters, o2 sensors, clean injectors...and timing from what I know. The NA has an aftermarket red anodized under drive crank pulley and the markings come out to 15 degrees using the PTU wire and #1 cylinder wire. I've read that a CAS aligned like this might be indication of improper timing related items.
