TwinTurbo.NET: Nissan 300ZX forum - found the problem
Subject found the problem
Posted by BlackholeZ on July 23, 2012 at 2:23 PM
  This message has been viewed 1809 times.
In Reply To Causes of 0psi Oil pressure? posted by BlackholeZ on July 21, 2012 at 04:51 AM
Message One of the check balls from the oil tree came out and made its way into the oil pump. Pump jammed, cracking the rear cover and tearing off the drive lobes. The crank is pretty chowdered at the oil pump drive, but it doesn't look like too much went through the bearings. I'll get pictures up later.
-Dan
BlackholeZ VTC Solenoid Caps and href="http://dl.dropbox.com/u/7320626/VTC%20Solenoid%20Cap%20Installation..pdf">Installation Procedure
"Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse."
"'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr
"full alphabetic boost mode" - ChristopherTheOne
"Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines
"You're the Skrillex of Z32s." BradX (UF)
