TwinTurbo.NET: Nissan 300ZX forum - Re: Hit bump, car dies, not a connector, fuel related likely
Krazyd27(Houston)
on July 23, 2012 at 9:41 AM
posted by treese88
on July 23, 2012 at 08:51 AM
Coolant temp sensor will prevent your car from starting, once when it gets warmed up. Mine was brand new but the wiring was corroded so every little bump would cause my car to act up and throw codes.
treese88
08:51:43 07/23/12
I would do the paper towel test for gas leaks. That hissing
zellamay
09:39:55 07/23/12
Already plan on new orings because the hissing leads me to
treese88
17:30:29 07/23/12
If you are smelling gas, it's leaking. Did you presssure
zellamay
21:12:32 07/23/12
Re: Hit bump, car dies, not a connector, fuel related likely -
Krazyd27(Houston)
09:41:00 07/23/12
I'll look it over. Mine has ~4k miles along w/ the harness.
treese88
17:33:55 07/23/12
Re: I'll look it over. Mine has ~4k miles along w/ the harness.
Krazyd27(Houston)
18:18:12 07/23/12
Other wiring problems can give this symptom as well.
ZXoltan
19:59:29 07/23/12
