TwinTurbo.NET: Nissan 300ZX forum - Code 55- No fault found (n/m)
Alan(MD/NJ)
on July 22, 2012 at 3:50 PM
absolutely effects idle.
posted by Antihero
on July 22, 2012 at 10:37 AM
Normal idle?
Alan(MD/NJ)
13:54:26 07/21/12
Re: Normal idle?
300ZMang
13:56:05 07/21/12
15.2 would be lean not rich. (n/m)
Evan_Wright (Ca)
14:29:00 07/21/12
with JWT 500 cams
HighPsi (NorCal)
14:47:07 07/21/12
Same cams (n/m)
Alan(MD/NJ)
16:24:12 07/21/12
Re: Normal idle?
Krazyd27(Houston)
14:57:41 07/21/12
10-30 (n/m)
Alan(MD/NJ)
23:12:52 07/21/12
well on topic
JRFITZ
15:09:24 07/21/12
That's the first thing I noticed too
Coldfusown
15:47:28 07/21/12
Car running only a couple minutes (n/m)
Alan(MD/NJ)
16:26:16 07/21/12
if the car was cold, the idle should be rich.
Antihero
23:14:17 07/21/12
You're over 900rpms, you should be 800-850 and smooth.
TriniTT
15:37:03 07/21/12
Re: Normal idle?
ZuL8tr300
21:26:24 07/21/12
Use to offer it to the community
Alan(MD/NJ)
23:10:45 07/21/12
I also have 500cams...
Devin300zx
22:23:09 07/21/12
Yeah like it wants to stall out or something (n/m)
Alan(MD/NJ)
23:11:40 07/21/12
With mine, ~850-900 sounds pretty good. (n/m)
PiotrC70
00:11:39 07/22/12
check your o2's if you idle doesn't always hover around 14.8 (n/m)
Antihero
23:13:27 07/21/12
I got a set of new OEM o2s
Alan(MD/NJ)
23:19:17 07/21/12
Antihero
10:37:32 07/22/12
Then I'm I already 95% sure of the problem
Alan(MD/NJ)
10:53:37 07/22/12
Code 55- No fault found (n/m) -
Alan(MD/NJ)
15:50:42 07/22/12
No code for a "lazy" O2 IIRC~Run O2 test (n/m)
BoneZ (MD)
22:42:29 07/22/12
bad O2`s rarely throw a code (n/m)
aliaZ
07:13:22 07/23/12
correction: warm idle (n/m)
Antihero
11:30:49 07/22/12
What does your boost controller read in vacuum? It seems
5280Z_nightstalker
11:09:32 07/22/12
if you're running selin, that's about right. That's what its
mkhoid
21:20:26 07/22/12
