TwinTurbo.NET: Nissan 300ZX forum - is the regulator stuck open?
Subject is the regulator stuck open?
Posted by aliaZ on July 21, 2012 at 7:07 AM
  This message has been viewed 204 times.
In Reply To Causes of 0psi Oil pressure? posted by BlackholeZ on July 21, 2012 at 04:51 AM
Message the regulator piston should slide smoothly in the bore.
Beyond that, I'd pull the pump to check that there isn't internal damage from ingesting debris...
There would have to be a huge internal pressure leak within the engine to have zero pressure...
What color is the glitter?
