TwinTurbo.NET: Nissan 300ZX forum - Low Beams and grounding at the switch
Subject Low Beams and grounding at the switch
Posted by Silens on July 19, 2012 at 5:23 PM
  This message has been viewed 208 times.
Message Quick question. I'm working on fixing my headlight issue. My high beams work, but when I switch the switch to low beam only nothing comes on.
I tested the switch out by grounding the pink and pin/black wires to the chassis and the low beams came on. I pulled the left pod apart and cleaned and checked all the internal contacts and they all look ok.
Any suggestions where I can look to figure out where the grounding issue is? I have been under the hood a lot recently and I may have missed a harness ground or something?
Thanks as always for the help!
