TwinTurbo.NET: Nissan 300ZX forum - Was the Car running ok before
njz
on July 19, 2012 at 3:07 PM
injectors ohm out, im gtting 12V at the connectors.
posted by ZiNnYc
on July 19, 2012 at 02:37 PM
extending the coil pack wiring and replacing injector connectors.
Is the ground and 12V appear at the proper connector pins?
Two cylinders fail PB test, need ideas
ZiNnYc
13:38:40 07/19/12
Start with check this.
njz
14:00:51 07/19/12
ZiNnYc
14:37:05 07/19/12
Was the Car running ok before -
njz
15:07:33 07/19/12
Did you notice this issue after replacing injectors, or has
Haasz32
13:24:31 07/20/12
are you sure the wiring isn't swapped between 4 and 6? (n/m)
aliaZ
07:10:45 07/21/12
