TwinTurbo.NET: Nissan 300ZX forum - Re: Re: 2nd Gear Grind Theory
Subject Re: Re: 2nd Gear Grind Theory
Posted by daygobaker on July 18, 2012 at 4:02 PM
  This message has been viewed 267 times.
In Reply To Re: 2nd Gear Grind Theory posted by 300ZMang on July 18, 2012 at 12:51 PM
Message Yeah the synchro is grinding for sure....but the cause of it might not be because of it being worn out...I dont know...its an easy inspection....I could see some members checking it out one day when they're bored too see if there rubbers are cracked or worn out....on the bracket...its worth a shot...to actually fix the problem then using a band-aid solution.
