TwinTurbo.NET: Nissan 300ZX forum - Re: Please help with repeated injector problem
Subject Re: Please help with repeated injector problem
Posted by Drunkpunk082 on July 16, 2012 at 9:24 PM
  This message has been viewed 213 times.
In Reply To Please help with repeated injector problem posted by Mike (Raleigh) on July 16, 2012 at 07:14 PM
Message Do the easy things if you havent... Swap coil packs, drive it around a bit. Also check plug for corrosion. Are you sure its the injector and not a spark problem? Verify the ECU is sending a signal to the injector by testing the plug side of the injector wiring.
