TwinTurbo.NET: Nissan 300ZX forum - Re: Boost inconsistant.. No low end.. Details inside!
Subject Re: Boost inconsistant.. No low end.. Details inside!
Posted by puchy on July 16, 2012 at 11:09 AM
  This message has been viewed 153 times.
In Reply To Boost inconsistant.. No low end.. Details inside! posted by Drunkpunk082 on July 13, 2012 at 12:36 AM
Message Good to hear from you, I was thinking on your problems with the car yesterday. I couldn't find some answers on a couple of things that I thought.
Why did you welded the cam sprockets and if you welded the intake cams? This could help explain the lack of low end torque depending on the valve timing it got welded on.
Why are you running 18psi? Race fuel? If you are running 93 octane it might be retarding the timing.
I have an ALC you can test if you want
