TwinTurbo.NET: Nissan 300ZX forum - Some advice
Subject Some advice
Posted by Drk93TT on July 15, 2012 at 1:12 PM
In Reply To I think my Fan Clutch is going out posted by 1911a1 on July 15, 2012 at 12:14 PM
Message It should turn about 1/2 a turn then stop.. if it spins freely the clutch is bad thats the easiest test on it.
What squeaks? Usually the belts will squeak at idle when too loose.. Check the belt defection and make sure not too loose or too tight
Stick with the OEM fan/cooling setup.. and get the shrouds all fixed up and in place for superior cooling as it was intended.
Does the car overheat? What leads you to believe the W/P is bad?
src="http://i47.photobucket.com/albums/f192/drk93tt/Picture6.p
ng">
