TwinTurbo.NET: Nissan 300ZX forum - JWT 400+ intake cam issues
Subject JWT 400+ intake cam issues
Posted by youngbloodz on July 15, 2012 at 4:20 PM
  This message has been viewed 293 times.
Message I had my motor built by IPP with 400+ cams I purchased from a locsl member here. Issue is that I have an issue getting the timeing belt to act properly. The intake cam lobes make contact on the edges of the lifters instead of the center like normal. What this is doing is making a sudden tension everytime the intake valves need to open, its so much tension that the timing belt will skip teeth (even with the right tension). This is all on an engine stand and the motor has never been run, just wondering if this has happened to anyone else?
