TwinTurbo.NET: Nissan 300ZX forum - TT - hard acceleration = slip to one side?
Subject TT - hard acceleration = slip to one side?
Posted by evan_aggie on July 14, 2012 at 12:35 AM
  This message has been viewed 192 times.
Message Maybe this is completely normal, but I never really had this problem with my NA engine (swapped to TT).
I notice under hard acceleration, when the boost begins to build to 8psi and up in 2nd gear, my car will begin to pull to the side for a second, and then I sort of let off the throttle and it straightens out. Now, I know this may seem stupid since it is quite possible that one tire is slipping a bit more than the other. However, I just wanted to check how common this was for folks?
I installed some decent coilovers that dropped the car, but I measured the setup to make sure they were relatively equal on both sides. I also have ST swaybars on the front and back.
I absolutely know that I still need an alignment on all 4 corners.
Just wanted to know everyone's thoughts....
