TwinTurbo.NET: Nissan 300ZX forum - Testing Aux. Fan on a TT.
Subject Testing Aux. Fan on a TT.
Posted by MixManMash on July 13, 2012 at 8:29 AM
  This message has been viewed 265 times.
Message In my quest to diagnose a slight overheating condition, I thought I would have a look at the aux fan.
In Nistune, using Consult Active Tests, I manually forced the "Fan Speed Low" and the fan came on via the radiator fan relay. I then manually forced the "Fan Speed High" and nothing. This should typically trigger the Sub Relay, but no click. I even tried swapping relays and nothing.
So my question is, does this trigger in Nistune not work on our cars? If it does work, why won't my ECU trigger the relay? Is it possible that I have an NA ECU when I really need a TT ECU?
