TwinTurbo.NET: Nissan 300ZX forum - Re: You need to get a timing light on it and check it.
Subject Re: You need to get a timing light on it and check it.
Posted by rhombicblue on July 12, 2012 at 12:47 PM
  This message has been viewed 124 times.
In Reply To You need to get a timing light on it and check it. posted by Draker (Eugene, OR) on July 12, 2012 at 10:45 AM
Message When you have ignition timing checked, also verify that slotted bolt on CAS is approximately in the middle of the slot. If the slotted bolt is at either end of the slot, belt may not have been installed correctly.
