TwinTurbo.NET: Nissan 300ZX forum - Re: Quick question...
Subject Re: Quick question...
Posted by ALee on July 11, 2012 at 12:44 AM
  This message has been viewed 173 times.
In Reply To Quick question... posted by inf on July 10, 2012 at 09:40 PM
Message Applying vacuum to EGR at idle should produce rough running; not sure which way the diaphram moves. Make sure solenoid is not blocking vacuum to EGR when off idle. When solenoid is activated by ECU vacuum is blocked. I had to unplug my solenoid to keep ECU from blocking vacuum path and this dropped my NO readings at 25mph by 450ppm.
