TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Ohm out the injectors and compression test the engine.
Subject Re: Re: Ohm out the injectors and compression test the engine.
Posted by LoRideChevy on July 10, 2012 at 5:51 PM
  This message has been viewed 218 times.
In Reply To Re: Ohm out the injectors and compression test the engine. posted by LoRideChevy on July 10, 2012 at 05:25 PM
Message i did a search, was be lazy... 10 - 14 across the injector i see.
whats the deal with the ptu?? could that have to do with the back cylinder fuel injector no working?
car was stored in bsmt garage with humidity, so corrosion is present, but i have been cleaning connectors for both injectors and coil packs...and putting di electric grease...
