TwinTurbo.NET: Nissan 300ZX forum - Timing is still fine. And although I recently had my engine
Evan_Wright (Ca)
on July 10, 2012 at 2:18 PM
Did you check to make sure something wierd like timing hasnt
posted by Red Hawk (CO)
on July 10, 2012 at 02:03 PM
torn down for gaskets and bearings and cam degree'ing I'd like to mention that before any of that was done I had a set of leader gears installed for about two weeks...the hesitation/stumble/miss was present then aswell.
Main causes of missing under high load?
Evan_Wright (Ca)
13:24:35 07/10/12
Red Hawk (CO)
14:03:01 07/10/12
Timing is still fine. And although I recently had my engine -
Evan_Wright (Ca)
14:18:25 07/10/12
Re: Main causes of missing under high load?
Stadsport (PHX)
17:31:24 07/10/12
The plugs have around 5k on them and they looked great
Evan_Wright (Ca)
18:17:02 07/10/12
I resolved this problem by installing Iridium spark plugs.
ThunderZ
20:30:52 07/10/12
Yep. Seems like heat range 7 is what SZ is recommending
MixManMash
21:12:56 07/10/12
But does it make sense that I would need to switch plugs
Evan_Wright (Ca)
21:48:08 07/10/12
It could be possible. If you have a log of before the gear
MixManMash
08:17:19 07/11/12
Interesting update. Drove it to work today and it idle'd
Evan_Wright (Ca)
12:57:42 07/11/12
strongly suggest that, my gauge has saved me multiple times (n/m)
Red Hawk (CO)
16:12:36 07/11/12
unfamous
23:48:00 07/11/12
Thanks for the suggestions. Have recently checked those all
Evan_Wright (Ca)
23:55:46 07/11/12
