TwinTurbo.NET: Nissan 300ZX forum - Possibly Bad O2's?
Subject Possibly Bad O2's?
Posted by PiotrC70 on July 06, 2012 at 10:15 AM
  This message has been viewed 189 times.
Message The O2's are both from my TT before the conversion, have about 40K on them and for all intensive purposes worked. Previously with my TT, when running datascan, I can see the Lean/Rich light cycling at idle and if I recall, went rich when accelerating. When viewing both banks and the throttle is blipped or I accelerate, the O2's would shoot up in value, and eventually level out.
NOW... Since doing the TT conversion, I haven't seen much of a response from the O2's. The Lean/Rich light remains LEAN at idle and even during acceleration, remains in the LEAN state. At idle, the left bank shows for example 15-18, while the right side shows 18-22 (at one point 25-ish). When I blip the throttle, each bank only goes up a point or 2, and not like I remember where it would go in the ex:60-80's.
Also, I took the car for a run with Datascan and also didn't see much of a response during normal cruising, or accelerating. At one point, I got on it pretty good and the left bank O2 dropped to ZERO where it remained for about 2 min of driving and came back up to a value well under 10. The right bank remained(fluctuating) below 10 for some time as well.
I haven't done the FSM voltage checks, but was hoping for a quick answer so I can get my hands on O2's before the end of the day.
Thanks!
1993 TT. R.I.P. 09.15.2010
