TwinTurbo.NET: Nissan 300ZX forum - Well, it is ground down now...after the fact.
Subject Well, it is ground down now...after the fact.
Posted by evan_aggie on July 05, 2012 at 1:18 PM
  This message has been viewed 187 times.
In Reply To Is your bracket ground away at all? posted by Woody75 (Denver) on July 05, 2012 at 11:10 AM
Message Yeah, no one mentioned that the bracket had to be ground away if you use the braided lines. I'm a little irked that they didn't tell me. I'll send them an email and make sure folks know. It was a massive PITA (as is most things) to get the compressor out and grind it away. Thankfully I hadn't charged my system yet with r134 because I had noticed a tiny leak still.
You'd be surprised. The bracket will bolt up almost perfectly w/o grinding it. The interference is probably no more than 2mm.
