TwinTurbo.NET: Nissan 300ZX forum - Re: Gas tank pressure release system
Subject Re: Gas tank pressure release system
Posted by ttcarguy on July 04, 2012 at 9:27 PM
  This message has been viewed 836 times.
In Reply To Gas tank pressure release system posted by RICH1 on July 02, 2012 at 03:26 PM
Message If you have removed your factory carbon canister then you will have a build up of pressure in the fuel tank. There is a check valve that seals the fuel tank under pressure. When vacuum occurs in the engine and your carbon canister is intact, the check valve is opened. When the carbon canister is removed the vacuum source for the check valve is lost and the fuel tank does not vent the gases.
See:
[ http://www.300zx-twinturbo.com/cgi-bin/manual.cgi ]
engine fule and emission control systems
pg 187
I have the same "problem"...my statements are from reading the FSM.
