TwinTurbo.NET: Nissan 300ZX forum - Would the pulley cause an intermittent sound?
Subject Would the pulley cause an intermittent sound?
Posted by Khronik on July 04, 2012 at 11:42 AM
  This message has been viewed 212 times.
In Reply To I'd guess idler pulley for the noise. posted by zellamay on July 04, 2012 at 10:54 AM
Message Until yesterday the sound only appeared with the AC on, tested it after work and it only made the sound with the AC on again
Ive tried burping the coolant several times but im missing the drivers side radiator spacer so that side is sitting the half inch or so lower than the other.
Plan on running to CZP for that and a radiator here soon..
Fan clutch is testing good but I also do not have a radiator shroud.. another part I plan on picking up asap
If it is the pulley should I be worried that it may pop off?
Had blue locktite on the stud into the block and red on the nut for easier removal of the stud at a later time
1991 NA 2+2 - Pearl White - Auto
1996 NA Coupe - Arctic White - 5Speed
1990 TT Coupe - Aztec Red - 5Speed
