TwinTurbo.NET: Nissan 300ZX forum - On the water leak - the AC cooling exhange coil is located
Subject On the water leak - the AC cooling exhange coil is located
Posted by jzack on July 03, 2012 at 9:54 PM
  This message has been viewed 252 times.
In Reply To 2 questions AC drain hose + mystery connector posted by Silens on July 03, 2012 at 08:07 PM
Message in a black box just above that hose (box is next to the round blower motor casing). Bottom of that box has a fitting for the drain hose to plug into. Shine a flashlight up there and look for the bottom of the box. If the fitting did break off - shouldn't be too hard to fab something up to fix the issue...
For question #2 - believe that connector goes to the hood pin security switch right next to it (plugs in the bottom side). That switch is supposed to have a moisture boot - not have the white pin showing. Often those boots crack and fall off and then the car's alarm goes off at random times due to moisture penetration.
One solution is to disconnect that connector and eliminate the false alarms. I totally eliminated that switch on my car to clean up the engine bay --
