TwinTurbo.NET: Nissan 300ZX forum - Re: wheel spacer question
Subject Re: wheel spacer question
Posted by artomason on July 03, 2012 at 8:31 AM
  This message has been viewed 192 times.
In Reply To wheel spacer question posted by KA8 on June 28, 2012 at 03:10 PM
Message I'm currently using the Z1 spaces, and I'm quite impressed with the fitment. As for the required size for the final offset that has much to do with personal preference and the width of your tire. The wheels I currently have are a 45 offset all away around, since the stock rear offset was 35 (now 45) I used 10mm spaces fro the front to push the offset out 10mm.
Front Stock 45mm ---> New Rim 45mm ---> Spacer ---> 55mm
Rear Stock 35mm ---> New Rim 45mm ---> No Spacer
Putting a 10mm spacer on the front SHOULD bring the front wheels back in line with the factory offset however this can change with the width of the tire, which was something I noticed playing around with a wheel fitment calculator.
Hope that Helps!
- Aaron
