TwinTurbo.NET: Nissan 300ZX forum - 2nd on changing the seals just due to age. The front
Subject 2nd on changing the seals just due to age. The front
Posted by jzack on July 01, 2012 at 9:33 PM
  This message has been viewed 163 times.
In Reply To I would change them. posted by Draker (Eugene, OR) on June 30, 2012 at 11:33 PM
Message main seal can be a PITA to get out. For any of the seals I've found that dimpling them a bit (using a small headed screw driver and hammer) at the 10 and 2 o'clock position makes it easier to get some WD-40 into the area The 60k FAQ refers to doing this as a way to pry it out. My preference is to use a seal puller instead.
Do the upper seals first - easier to get the hang of things before trying the crank seal.
PS - Run a web search for this seal puller to buy: Lisle 58430 Shaft Type Seal Puller
