TwinTurbo.NET: Nissan 300ZX forum - How can you pump and bleed at the same time?
Subject How can you pump and bleed at the same time?
Posted by Joe@ZSpeedperformance on June 30, 2012 at 9:14 PM
  This message has been viewed 232 times.
In Reply To Bleeding Clutch Problem!!! posted by s1man711(CA) on June 30, 2012 at 07:38 PM
Message Is someone helping you? If you are having problems getting the car in gear with the car off that would probably mean something is wrong with the shift linkage or trans.
Are your bushings ok in the shifter?
Is your shifter mount bolted securely to the trans?
