TwinTurbo.NET: Nissan 300ZX forum - Hard start and fuel pressure questions
Subject Hard start and fuel pressure questions
Posted by Silens on June 30, 2012 at 3:32 PM
  This message has been viewed 330 times.
Message I'm having some hard starting issues with my 91 NA 300zx. I'm not super clear on how the fuel system set up on these cars is rigged, so I thought I would ask the experts here.
I hooked up an inline fuel pressure gauge after the fuel pump, while the car was running it looked ok, it was a little over 40psi until the idle stabilized and then it was 36 or 37psi at idle. This seems pretty consistent with what I understand is the operating pressures of the rail.
The question I had was that as soon as I turned the car off the pressure gauge instantly dropped to 0psi.
On these cars if I have the gauge hooked up immediately after the fuel pump, between it and the fuel rail should I be seeing a 0psi state when the car is not running?
It would certainly explain my hard start if the entire system was at 0psi every time I wanted to start it.
