TwinTurbo.NET: Nissan 300ZX forum - Loosen the two 17 mm bolts on the front of the bracket
Subject Loosen the two 17 mm bolts on the front of the bracket
Posted by SilverTwin(OH) on June 30, 2012 at 12:27 AM
  This message has been viewed 265 times.
In Reply To Not sure what happened... posted by 4-EZTT on June 29, 2012 at 07:28 PM
Message Just loosen or remove the two 17 mm bolts on the front of the tension rod bracket, that will allow it to move in order to align everything again. Once you have the brackets aligned and the bolts started, torque everything back to spec.
'91 TT
ZROC -The Z and Roadster Club of Ohio
CincyZ- The Southern Ohio Z Spot
