TwinTurbo.NET: Nissan 300ZX forum - non turbo transmission modification
Subject non turbo transmission modification
Posted by mapsz32 on June 29, 2012 at 10:55 AM
  This message has been viewed 233 times.
Message Hello , i have a tt engine droped in already in my 2+2 car,i will use my original 5 speed transmission from non turbo,the flywheel/clutch i planning to use are the twin turbo setup, so that beign said ,here's my question, is neccesary to grind a little bit the inside of the bell housing where the flywheel rotate? in order to fit that slightly bigger flywheel.
Anyone done this w/out grind the housing??? thanks...
