TwinTurbo.NET: Nissan 300ZX forum - Sounds like the starter to me as well.
Subject Sounds like the starter to me as well.
Posted by weezee on June 28, 2012 at 7:41 PM
  This message has been viewed 229 times.
In Reply To Maybe the starter wheel is not fully engaging and causing posted by AsaHerring on June 28, 2012 at 06:18 PM
Message If the starter or the battery is bad, you'll get that ticking/grinding noise where the starter solenoid is trying to engage the flywheel, but it just doesn't have the ability to. If a new battery doesn't make it start, then I'd check all connections to the starter. If that's good, the starter may be bad.
“Gentlemen, you can’t fight in here! This is the War Room!" — Dr. Strangelove
