TwinTurbo.NET: Nissan 300ZX forum - Maybe the starter wheel is not fully engaging and causing
Subject Maybe the starter wheel is not fully engaging and causing
Posted by AsaHerring on June 28, 2012 at 6:18 PM
  This message has been viewed 245 times.
In Reply To Gruesome sound when trying to start posted by dvice on June 28, 2012 at 09:23 AM
Message the teeth to grind on the fly wheel. If you made the video from inside the car I could tell you if that's what it is. Mine does it often but I don't know what sounds like from outside the car. Sounds too consistent to be the starter grinding. Probably a bad battery. Enough power to run but not start. Can you start it at all?
