TwinTurbo.NET: Nissan 300ZX forum - Re: Car won't attempt to crank! Please help!
scottmt21
on June 27, 2012 at 6:13 PM
posted by NismoDHS
on June 26, 2012 at 10:40 AM
You might check the starter wire under the car, it has a plastic connector that gets old,hot & brittle> Mine came apart and I could hear the relay clicking in the drivers fender but no starter! Just put it back together and clean and tape it.
NismoDHS
10:40:01 06/26/12
Clutch switch: is at the clutch pedal in the cab. Quick
zellamay
10:58:28 06/26/12
Re: Clutch switch: is at the clutch pedal in the cab. Quick
NismoDHS
11:32:47 06/26/12
As I remember, that switch is adjustable. Can you just
zellamay
11:52:49 06/26/12
P.S. there's usually a no-return policy on electrical parts.
zellamay
11:56:41 06/26/12
Re: P.S. there's usually a no-return policy on electrical parts.
NismoDHS
12:35:45 06/26/12
have you checked to see if the terminals are getting full
mkhoid
06:37:30 06/27/12
Re: Re: Clutch switch: is at the clutch pedal in the cab. Quick
Krazyd27(Houston)
14:15:58 06/26/12
I have your answer. Inside d/s fender well is starer relay
craigz96tt
13:40:32 06/27/12
Re: Car won't attempt to crank! Please help! -
scottmt21
18:13:43 06/27/12
