TwinTurbo.NET: Nissan 300ZX forum - Re: Sizzle noise from behind the engine.
Subject Re: Sizzle noise from behind the engine.
Posted by Medallion Man on June 27, 2012 at 3:07 AM
  This message has been viewed 268 times.
In Reply To Sizzle noise from behind the engine. posted by AsaHerring on June 27, 2012 at 01:10 AM
Message Hi,
I'm in the UK and a little jealous of the hot weather you're having...
from my understanding best case is it could be the air con.
however there are a lot of little pipes around that area that have water/coolant in them.
so it could be the hoses to/from the heater matrix, or the turbo water feed, or the water/coolant pipes under the plenum.
All can come a bit loose or leak in hot weather.
check the water/coolant levels in the rad ,try parking it on a steep an uphill slope you can find to eliminate any air pockets.
Oh, and make sure you use a decent coolant.
good luck..
