TwinTurbo.NET: Nissan 300ZX forum - Clutch switch: is at the clutch pedal in the cab. Quick
Subject Clutch switch: is at the clutch pedal in the cab. Quick
Posted by zellamay on June 26, 2012 at 10:58 AM
  This message has been viewed 246 times.
In Reply To Car won't attempt to crank! Please help! posted by NismoDHS on June 26, 2012 at 10:40 AM
Message test is to pull the plug off it, then put a jumper in the plug. A piece of wire will do for a quick test. (I left it this way because I didn't want a clutch switch at all.) ....... Does the starter relay now "click" when you turn the key? If so, then another thing to do is look at all the wires at battery and starter for breakage, disconnection or corrosion. If in doubt, clean, fix or replace. Make sure the cable is secure on the starter (I once had the shop forget to tighten that nut, so the cable came off.) If the relay doesn't "click", then I'd check to see if it's getting 12v when the key is turned, which might suggest ig switch.
