TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Check PTU and clean all contacts very well
Subject Re: Re: Re: Check PTU and clean all contacts very well
Posted by Medallion Man on June 26, 2012 at 3:10 AM
  This message has been viewed 148 times.
In Reply To Re: Re: Check PTU and clean all contacts very well posted by HiFiveZ on June 25, 2012 at 03:31 PM
Message mas, ptu and cas connectors, used emery paper/board and electrical contact cleaner (in a spray can) no residue.
when you do the timing make sure you use a timing light (reading it from conzult or other software is a waste of time) and it should be 15 off TDC.
NGK Pfr6-11b platinum ...
iridium plugs are not designed for the VG30, they need a higher revving engine to self clean properly..
that is reported to have been said by a guy from NGK.
