TwinTurbo.NET: Nissan 300ZX forum - injector replacement
jjamez
on June 25, 2012 at 8:46 PM
when replacing injectors, is it easier to remove the fuel rails, once the plenum is removed. or is there some difficulty in removing the rails. i'm considering buying a kit, where the injectors are already installed in the fuel rails.
injector replacement -
jjamez
20:46:56 06/25/12
Yes it's easier to remove the rail and work with it on a
mkhoid
21:29:01 06/25/12
and once on your bench -- use a vise and some larger
jzack
22:59:58 06/25/12
dont forget to lube injectors before doing all that, it will
mkhoid
00:43:04 06/26/12
I think he meant trying to sneak the rail out from under the
Red Hawk (CO)
09:53:14 06/26/12
