TwinTurbo.NET: Nissan 300ZX forum - trans plate, off??
Subject trans plate, off??
Posted by ouikikazz on June 25, 2012 at 3:47 PM
  This message has been viewed 289 times.
Message went to put on the transmission plates on my engine (which is hard enough missing a dowel pin on the pass side block) but in any case went to line it up and the top 6 bolt holes are fine, the bottom 4, with the brackets that attach to block...do not, is that normal? (i don't think so) all those brackets are tightly secured really no wiggle room to adjust, its quite far off too...i lined up the big plate to the transmission and it lines up fine, so thinking i have an issue here??
