TwinTurbo.NET: Nissan 300ZX forum - Re: controlling the z32 TT engine heat?
Krazyd27(Houston)
on June 24, 2012 at 10:55 PM
posted by evan_aggie(ATX)
on June 24, 2012 at 10:29 PM
I also would like some feedback on this
evan_aggie(ATX)
22:29:05 06/24/12
Re: controlling the z32 TT engine heat? -
Krazyd27(Houston)
22:55:23 06/24/12
Re: Re: controlling the z32 TT engine heat?
elcid
23:01:04 06/24/12
First, make sure everything is right. It's hot in AZ,
zellamay
23:40:37 06/24/12
It was 101 yesterday in Austin, but my gauge reads normal.
evan_aggie(ATX)
07:44:07 06/25/12
Check out "Billion Highflow thermostat" posting today
zellamay
10:07:23 06/25/12
Put the undercovers back on and direct as much air as
Xteam300TT (South Tx )
18:17:57 06/25/12
What temp gauge are you using ? If youre using the stocker
18:24:34 06/25/12
Just a few suggestions
AsaHerring
00:36:27 06/25/12
Look up the Mod to run you aux fan on low setting often (n/m)
Red Hawk (CO)
13:30:05 06/25/12
I will, thanks! (n/m)
AsaHerring
18:44:19 06/25/12
MaxxAction
21:14:36 06/25/12
elcid
21:40:06 06/25/12
Yes. You've got the assignment: design a system that works
zellamay
09:51:32 06/26/12
pilikua
23:42:11 06/25/12
Doh. I've already done that. I guess it's just going to
evan_aggie(ATX)
08:07:00 06/26/12
I think that, in theory, dp's would help a little, due to
zellamay
09:58:07 06/26/12
P.S.: If you want dp's to help with under-hood temps,
zellamay
10:01:25 06/26/12
Mine are wrapped. Actually, some folks say wrapping the
evan_aggie(ATX)
16:22:13 06/26/12
evan_aggie(ATX)
17:05:48 06/26/12
