TwinTurbo.NET: Nissan 300ZX forum - Looks like t's dripping on top of the turbo.
Subject Looks like t's dripping on top of the turbo.
Posted by 90GoldZ on June 24, 2012 at 12:59 PM
  This message has been viewed 103 times.
In Reply To Spot this leak??? posted by s1man711(CA) on June 24, 2012 at 09:57 AM
Message Seeing that the turbine housing is wet with oil, I would point to a leaky valve cover gasket, or a leak through the half moon seal.
The dripping on the line and the cartridge on the turbo could be from the oil drain.
Check the oil feed line and make sure it's tight on the fitting, and if possible, try to take some pictures from the engine bay looking down at the turbo.
