TwinTurbo.NET: Nissan 300ZX forum - Look over your d/s fender below the brake mc
Subject Look over your d/s fender below the brake mc
Posted by 1911a1 on June 24, 2012 at 12:21 PM
  This message has been viewed 113 times.
In Reply To follow that line down and it goes to a short rubber hose posted by Red Hawk (CO) on June 23, 2012 at 10:03 PM
Message You'll see two hard lines attached to the frame rail. The line on the left is the return line from the pressure regulator. The hard line on the right is the inlet coming from the pump running to the filter and on to the dampener/fuel rail.
If it's still oem, you'll see an oem squeeze-type clamp on the return line as this is a low pressure line. The inlet will have a screw-type fuel line clamp on it.
