TwinTurbo.NET: Nissan 300ZX forum - ****** solved ***************
Subject ****** solved ***************
Posted by hellraz0r1337 on June 23, 2012 at 1:51 PM
  This message has been viewed 249 times.
In Reply To Re: well that in itself sounds like a boost leak posted by hellraz0r1337 on June 22, 2012 at 01:51 PM
Message problem was a code 13 bad coolant temp sensor. i had previously cleaned this connector respliced a new plug on and figured everything was ok.
did ecu diagnostics came back 13 went and bought a new sensor and bam instant run drove around the block a few times to get it nice and warm brought it home shut it off and it works again.
If your having problems with car not starting when warmed up or after it ran CHANGE THIS DAMN SENSOR
thanks for your help guys i appreciate it (REDHAWK)
