TwinTurbo.NET: Nissan 300ZX forum - Why not use both the Antenna.
Subject Why not use both the Antenna.
Posted by artomason on June 23, 2012 at 9:20 AM
  This message has been viewed 276 times.
In Reply To After market radio reception issue SOLVED! posted by Mike (Raleigh) on June 21, 2012 at 03:07 PM
Message If you wish to use both of the antenna (Rear Window and Mast) you simply solder a wire between the two prongs near the base of the male connector. The original artical can be found at the following location
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=871047 ]
A few notes, however. You will greatly increase the reception if you solder a 26GA wire in rather than just wrapping it like the write says, at least from my experiance. You just need to be certain that the wire is completely at the base of the male connector when you solder else the connecter will not reassemble as advertised. This should fix not only the connector being backwards, but you should gain the use of both antenna rather than just one or the other.
