TwinTurbo.NET: Nissan 300ZX forum - Re: Issue
Subject Re: Issue
Posted by 300ZMang on June 23, 2012 at 12:41 AM
  This message has been viewed 137 times.
In Reply To Issue posted by BannonZ on June 22, 2012 at 01:30 PM
Message Usually if it's running rough, it's lean. But then you smell gas which means rich. So you're probably looking at an injector issue here for sure. Which cylinder is it? Did you isolate it by the power balance test? Sounds like the injector is getting stuck open, then closed, etc. Did you Ohm test it? Could also have the wrong lower o-rings on your injector or have pinched rings, causing rich conditions.
