TwinTurbo.NET: Nissan 300ZX forum - well that in itself sounds like a boost leak
Subject well that in itself sounds like a boost leak
Posted by Red Hawk (CO) on June 22, 2012 at 1:45 PM
  This message has been viewed 226 times.
In Reply To Re: Re: The gauge needs to be T'd on the line between the rail posted by hellraz0r1337 on June 22, 2012 at 01:17 PM
Message We can't keep playing this game of what ifs. Your car has issues, and if you're like me you go crazy, foam at the mouth, and try to fix her immediatly...totally understandable; but until you get some actual info on whats good and whats bad on your car, no one can help you much more than i have. So go get your tps adjusted, cas adjusted, boost leak, fuel pressure test, power balance, and code check ( not in that particular order) and see if anything is out of spec. the search and faq on this site has loads of information on trouble shooting and its all diy so your not spending money at a shop.
Good luck! and report back if you still can't solve it.
TT BEAST IN PROGRESS!
