TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Seated injectors into the rail by means of using cap?
Subject Re: Re: Seated injectors into the rail by means of using cap?
Posted by hellraz0r1337 on June 21, 2012 at 10:43 AM
  This message has been viewed 276 times.
In Reply To Re: Seated injectors into the rail by means of using cap? posted by hellraz0r1337 on June 21, 2012 at 08:13 AM
Message ALSO i noticed that the z1 adapter kit does not utilize the middle of the injector. Does that make a difference? like the old injectors had a metal spacer / insulator than the cap sat on that. On the new injectors and adapter kit i dont use these spacers and the cap sits around the outside of the injector.
Also you do leave the plastic pintle caps on right? lol cause i had the injectors tested twice from JWT and deatschwerks and they left the caps on so did i
